Hello.
In the olden days when I was a youngster, I could weld a bit, not pretty but held things together.
Have dug my old welder out for a practice & can't for the life of me get a bead. I've read guides, watched YouTube and spent a number of hours practising.
I've got some bits of new/clean 3mm steel, ground shiny and brand new 2.5 Bohler 6013s.
Most of the time it's like the slag & filler are being blasted away. I weld along, but after there is practically nothing there, just the odd blob of weld & slag. This isn't mentioned in the guide to faults on this site! I'm using the amp range 65-85 ish. If I drop the current to 60/65, the rod sticks. I've tried more/less current, faster/slower, various angles, arc length. Rods are dry, been in airing cupboard.
I can't get any penetration either.
I would have thought I would have improved a bit in the 6 hours or so that I've spent, but it's as bad as the start.
Can the machine go bad? - I know they're pretty basic & reliable as there's not much to them.
Could the steel be 'wrong'. It is about 25mm x 3mm in ca 5m lengths galvanised - it's something specific as there's loads of it in tubes in a dinghy compound.
I'm at a loss and any tips would be appreciated.
