Where'sMyBrew?
Hi
although this question is strictly more to to with electrics rather than air compressors, this forum strikes me as a very helpful place to newbies, so here goes.
When I had my home garage re-wired by a professional electrician, I had separate 16amp and 32amp sockets wired straight from the consumer box. The 16amp now happily supplies my Portamig 210 MIG welder.
I had the 32amp supply installed in anticipation of eventually getting a meaty air compressor. I had no real knowledge of compressors at the time, other than vaguely being aware that a higher-rated supply might be required. A bit of forward-thinking for once in my life
Anyhow, the time for me to get a compressor had arrived.
From reading these forums, it seems that (up to) 20amp should be sufficient for most mid-range DIY compressors.
So to finally get to my question: what, if any, would be the risk of wiring a compressor requiring, for example, 20 amps, into a 30amp supply ?
To mitigate any risk, would it simply be a case of replacing the 32amp MCB with a lower rated one in the consumer unit ?
many thanks,
Gareth.
many thanks,
Gareth.
