monkeh
- Corby UK
Good Morning,
I have just bought my first compressor sgs 3hp 50L. I'd like to fit it up to some 22mm copper pipe to condense the water out of the lines but im struggling to work out how to connect it to the tank.
The compressor has a 1/2 bsp nut on the tank which im going to use instead of the 1/4 bsp on the regulator.
Whats the best/cheapest option to connect this to the copper pipe? I'm thinking a 1/2" bsp pcl xf quick release coupler on the tank, then making a 1/2" line up with a pcl hosetail one end and a female 3/4"hosetail the other.
Then i should be able to solder up the connectors, piping, drop legs and taps etc. Then at the other end i'll need to attach a 3/4 filter/trap regulator and then i think i'll have to fit a reducer down to 1/2" to fit a pcl xf coupler?
Can solder joints take the pressure with the hot air? What about compression fittings?
I have only a little experience with compressors and plumbing so any advice and places to buy it all cheaply much appreciated.
cheers
compressor specs:
Engine Size: 3.0 HP
Power Consumption: 2.2 kW
Voltage: 230 V @ 50 Hz
Rated Speed: 2850 rpm
Current: 10 A
Air Displacement: 14.6 CFM
Sound Level: 97dB
Discharge Pressure: 115 PSI / 8 bar
Restart Pressure: 80 PSI / 0.55MPa
Tank Capacity: 50 litres
Air Outlet: 1/4" BSP to Euro Coupler. The fitting can be swapped for PCL fittings, please check Fitting & Couplers section.
Dimensions: (L) 750 x (W) 380 x (H) 770 mm
cheers
compressor specs:
Engine Size: 3.0 HP
Current: 10 A
Sound Level: 97dB
