Craig-SM
- Heckmondwike
I am finding conflicting information on the best location for the water trap. Some say on the compressor outlet so it catches some of the rust and debris, whilst others say it should be ideally be around 20 feet from it so the air cools down enough for the water to condense and the filter to work better. What are you thoughts?
Just for information I have a 100 ltr 3hp Clarke compressor (no regulator fitted). This is located behind a partition in the garage with my work bench on the other side where a 5m rubber pipe feeds the air through going up to roof height and then back down again so any water will drain down to the ends of the pipe. The water trap/regulator needs to be fitted either at the start of the rubber pipe or the end but which.
My thoughts are at the end so I can control the regulator where I'm using the air.
