i managed to remove the rusted in adapter from my compresor last night but as i was using heat i removed the plastic bleed pipe that runs right by it as i didn't want to melt it.. However the olive ring had been crushed that much that it was impossible to get the pipe out and bacsically to cut a long story short the end of the plastic pipe got stuck in the hole and wouldn't come out but eventually did but i ned a new olive as this one is ******ed.
howvere i spoke to SIP and the part is only £1.24 but P&P is £8!! now i refuse to pay that, the lazy robbing gits!! do you think the olive will be a standard fitment?
the plastic tube has a small top hatted cylinder that goes in the end of it to give it some internal resistance when the olive is tightened i guess. and there is a tapered face that the olive is pressed against when the hollow nut is tightened against it
similar to this
anyone knwo if these are going to be standard fitments?
cheers
similar to this
cheers
