My compressor started blowing fuses so I started to investigate without belt on it runs fine motor side minute you put belt on the motor tries to move then blows a fuse?. It's quite stiff to turn the pump by hand should it be like this?
You know the cams, the ones that spin the supercharger....
Looking at the picture I'd say whatever is on the tops of the pistons shouldn't be there. Looks like alloy filings or if it's paint dust it ain't done it much good.
doesn't need to be the same model and make as long as the pulley sizes and speed of pump are the same and it will fit on the mounting plate. u may have to alter the outlet pipe to tank
