indy4x
- Pontypool, South Wales. UK
Hi
I have a Clarke air compressor fitted with a 3HP single phase motor. It's been in bits for a while as it's previous owner had run it in a carpentry shop with a broken air filter so was full of sawdust.
I've stripped and cleaned the pump, fitted a new pressure switch and replaced the 3 core cable from the plug to the switch and switch to the motor
It ran for the 1st time yesterday and I have a problem with it blowing fuses.
The fuse blows on startup, the motor will start up, get almost to running speed and then the fuse blows. Doesn't happen every time but is getting more frequent.
Double checked my wiring and that's all good but the run capacitor is not pretty. Bottom of the case is bulging and the top cover where the wires go in looks stained as if something has leaked
The capacitor is 45 uf +- 15%, I have a new spare capacitor but it is 60 uf +-5%
Will this be ok in the motor even it it's only short term while I order a new one
