Hi,
I'm fairly new to spray painting, after a few attempts have had some good successes with an HVLP gun and 2k paint. I have been looking into compressor capacity a bit, because there is a lot of information (misleading or otherwise out there). My question is this:
- The air flow required for my spray gun is max 300l/min at 4 barg.
Converting to normal litres/min, this means the air requirement is 1500nl/min
- The (small) air compressor has a FAD of 160l/min at 8barg
Again converting to nl/min, this gives 1440nl/min
Ok, so comparing the nl/min the small air compressor is close to the required capacity, but not close enough, especially if you want a good 'safety' margin, for example 50%.
In order to correctly compare air flow requirement with air flow capacity shouldn't all calculations be done in nl/min to avoid any confusion? I see a lot of text with people citing for exampe ' 12cfm required for spray gun, so find a compressor that matches 12cfm' but this takes no account for the HVLP gun using a lower pressure than the compressor's FAD quoted value.
Please correct me if I'm wrong! I have probably overlooked the obvious...
