drivewasher
My 50l fiac miami compressor can't keep up with a brand new air ratchet (not a cheapo one) tool should consume 4 ltrs a min..
The cfm of compressor is 13 cfm min ACTUAL FAD is or should is 8.66 cfmmin. so compressor should at least keep up with the ratchet
So I emptied the 50 ltr tank and timed it to fill up to 145 psi and it took 3.5 mins, can anyone who attended school on the day we did maths work out if thats about right.
Also to get the line pressure at 90 psi when running tool the regulated pressure needs to be about 120 psi when not running tool in order to get it at 90 psi when it's running, but as the tank soon empties then the gauge will continue to fall along with the emptying of the tank
I blocked the inlets off to the cylynders one at a time and repeated test both cyls took about the same time to getup to 100 psi.
I need this comp working as I'm opening a tyre bay next week! Hoping this comp will do for a few months
