Hi after it has tripped the first time it then constantly tips after resetting each time, no I haven't touched the red knob at any stage.After it's tripped for the first time does it then run for a further 2 mins after re-setting then trip, or does it trip straight away without running?
After it tripped for the 1st time did you release the pressure in the pump by switching the red knob to off?
No the compressor is a direct drive unit similar to the Airmaster Tiger8/44 single phase.There's probably a centrifugal switch in the motor that you can hear clicking. If it doesn't open when the motor is up to speed, the motor could overheat.
Is it a belt driven compressor? If so take the belt off and see if the motor still cuts out.
