julianf
- devon, uk
Ive got a 14cfm compressor. Its right on the edge of being able to run from a 240v socket. If i ever try to run it from an extension lead, it just blows the fuse in the lead on the first revolution.
Today, i had it plugged into one socket - started it, revved once, and then blew the fuse upstream of the socket.
Move it to a different location.
Revved one or two times, and stopped (did not blow the fuse).
Tried this a couple more times (ie off, then on again) and would rev a couple of times and stop each time.
...then wouldnt do anything. Ive checked the thermal overload switch and its not that. Ill check the fuse in its own plug, but, even if it is that, there's still something up.
The unit is a Fiac Michigan, which you probably wont find on any searches, but its just a standard, direct drive unit. It looks like this -
or there abouts.
I figure -
I may have melted the windings by trying to start it too many times, in which case its game over.
Or its a capacitor issue.
Or there is some other reason why its trying to pull too much power.
(it has oil etc. and i was using it yesterday, so its not like its been stood for years)
Any other suggestions?
or there abouts.
I figure -
..need to think on your feet around these animals
