Greeves250
New Member
I made an earlier post on this compressor but haven't fixed the problem. To recap - it was suggested that I drain the compressor and flush it. Short of running it with parafin for a while (which I'm loathed to do) I've replaced the old oil and run it up but the problem persists. When it gets to 50psi the belt slips (just like it did before with the old oil). With 50psi in the reciever the pulley seems hard to turn by hand like turning over a big 2-stroke motorcycle engine and feeling the compression (conversely with no pressure in the reciever it feels easy to turn by hand). Could it be that air is backing up into the compressor?. Is this possible?. Could it be a faulty NRV (non return valve) or something to do with the cylinder head?.
