Hey,
I need a littel advice about compressor fittings (this i an unusual application!)
I currently have a compressor that uses 1/4" PCL quick release connectors.
I also have an oil barrel bbq that I give a little boost using the compressor and a air blower attatchment.
I decided it would be a really good idea if i could run some brake hose inside the bottom of the oil barrel and connect it to the compressor with a valve.
Ive found this - 1/4" Ball Valve
I will attatch this to the leg of the bbq and have one PCL connector on one end, allowing me to conect the air line easily. the valve should then allow me to control the air flow.
The problem I have is connecting the copper brake hose to the other end. I need to find some way of connecting 3/16" copper to 1/4" BSP.
Any Ideas?!!
thanks!
Any Ideas?!!
thanks!
