julianf
- devon, uk
Following on from my issue with junk getting stuck in the non return valve on my compressor, i think ive got reduced compression.
Motor seems to run for longer to get to pressure.
This, coupled with, what i found in the nrv (it happened twice in total) -
The first time seemed to be just black rubbish, but the second time was either a flake of epoxy primer overspray buildup, or, worse, white metal. It was only small and i couldnt really tell.
The compressor is an old "airmaster" (clarke) thing. Google images actually came back to a thread here ( https://www.mig-welding.co.uk/forum/threads/airmaster-compressor-help-required.11336/ ) but the pump on mine is very slightly different.
I think my pump looks more like this one -
...but there are so very many small variants of the same thing. It has a plate on it, so ill see if anything sensible is written.
Anyway, the question -
You can see the expected age on the local forum post i linked to above. Is it likly that parts would be availible, and should i even bother? I mean i dont know what a gasket set will cost, but if its £20 + vat + delivery im probably to £35 to even look inside, and a whole new pump is about £150 and then i know it will "just work" (or at least that would be the hope!)
