Hi guys,
Looking for a bit of advice on my hydrovane compressor motor. Its an old 1985 3hp single phase motor. I have just stripped it down to replace bearings and rewired the terminal box due to it being very old and most of the insulation had fallen off the cores leaving loads of bare copper.
Anyway, here is some pics for a start.
Now when i stripped it down, one of the first things I come across was the mechanical centrifugal switch, but I dont have a clue how or if it works? there is a mechanical part on the commutator which seems to function fine - it appears like it would throw out easy enough as speed. but there is no electrical switch or any other parts near it? so how does it work?
secondly, can anyone explain what terminals are what? I know the pic isn't to clear but I cant work it out. I have no idea what type or size the capacitors are bolted to the outside as they have been painted over but they do appear to be similar in colour to those inside the terminal box.
I have fired the motor up as it stands just now and it does appear to run as it did before - just without the bearing rattle. I have only replaced parts like for like so any problems or parts missing have been like that for a while. I have put quite a few hours on this motor so far.
Cheers in advance
stef
Cheers in advance
stef
