agree but what you can do is fit an idler, flat pulley as per timing belts on the slack side of the belt to increase the 'wrap' of the smaller pulley.what u may have to watch is if making the motor pulley smaller is belt slip if u have to go smaller than 3 inch . a 4hp single phase motor would be better
yes that helps but not always successful I have one on my donkey saw because of belt slip and its still a bit iffy on a good cut .don't know if his comp is twin belt drive or a rather thick wedge beltagree but what you can do is fit an idler, flat pulley as per timing belts on the slack side of the belt to increase the 'wrap' of the smaller pulley.
You Saw ---- many donkeys then ??, is this a magicians trick?I have one on my donkey saw
they don't like the starting load of a compressorYou can get the 240V to three phase converters and run a three phase motor from domestic mains power.
yea I got one. 2 pumps and 2x 3hp motors over a grand if u want one mine was 60 quidIf I recall correctly, you used to be able to get big compressors with twin single phase motors.
The ones i am thinking on used the two motors to run the same big pump.yea I got one. 2 pumps and 2x 3hp motors over a grand if u want one mine was 60 quid
