sixtwoeight
Hi, ive just spent all my pocket money on 2x 3hp compressors, each compressor has a 1/2" bsp un-regulated outlet. My plan is to run the pipework from the compressors using Malcolms plan from his tutorial with the 2 linked together. The run of pipe will be approximately 15-20m. Should I use 15mm copper pipe, or step up from 1/2bsp to 3/4bsp at the compressor outlet then use 22mm copper pipe. As I would then need to reduce down again for regulators and filters would I be gaining anything by using the 22mm pipe? (im assuming 22mm would give me less pressure drop over the distance, but didn't want to spend the extra on the larger pipe unnecessarily. (read, tight wad!))
Many thanks
Many thanks
