I have read all sorts on here and other sites with regards to considerations for compressor pipework. I have bought a Clarke SE37C270ND which has a 1/2 inch ball valve on with a 3/4 BSP female outlet and I want to put some pipework in place so I can run various tools.
My main considerations are that I need a wide bore direct connection to my blasting pot and an outlet for my air tools. I would like to extend to other outlets later but not important right now.
I understand that the best connections for the air tools are EURO as opposed to PCL? I only recently changed my airtools to PCL so I guess I would need to change them back again!!
I further understand that there are then a number of other considerations - widest bore pipework is best (e.g. 22mm??), water trap(s), water drier(s), pressure regulator, flexible pipe from the compressor to minimise connections loosening through vibration.
Is there a guide or better still a diagram anywhere that illustrates whats best? I have seen the other thread on this but this is based on 15mm and just a normal regulator/separator.
I only want to do this once and would like to get it right for my needs.
Thanks
D
Thanks
D
