I have bought a bench top switzer blast cabinet and I am using a friends compressor which is approx 1 month old and hardly used.
https://www.spawelding.com/air-equipment/compressors/150ltr-compressor.html
It worked fine yesterday but today, it has started tripping the reset button (positioned above the motor in the pic ).
I have the psi set @ 90 coming out of the compressor and into a water trap where it is set to 80psi and I am using a 5mm ceramic tip.
The top aluminium fins get very hot and when I start using the gun, the compressor cuts out instead of kicking in and I have to hit the reset button and wait for it to cool before I use it as it's not my machine.
It seems to be an overheat issue but I wanted to ask incase I am doing something wrong.
the pipe running from the piston area to the tank is approx 22/25mm and is also very hot...you can touch both areas but only for a second
