andytm
ive just aquired a new compressor its an old motivair one with a broom an wade compressor motor on it ,we wired up the three phase supply i then removed the belts to check which way the motor spins and also turned compressor over by hand to see if i could tell which way that needed to spin to build up pressure but it appears to be buildng up pressure both ways , should it do this?i then put the belts back on and switched it on .it ran for a minute or so and began to slowly build up pressure but then a small amount of smoke appeared from the electric motor so i quickly switched it off. im wondering if i maybe have a stuck valve causing too much pressure on the electric motor any thoughts on this ?
