buy a blank pulley and bore it to size if u cant get the shaft size you wantI am in need of a small compressor pulley. (Motor side) Sizes to follow.
But where is the best place to locate one??
Yeah problem is i am chasing my tail....everything going wrong. 1 after another.buy a blank pulley and bore it to size if u cant get the shaft size you want
Not sure this is taper lock as it has a keyway and large key.Most bearing suppliers stock "taper lock" pulleys, they come in all sizes and are made from cast iron.
There blanks bud. Will need to drill bore and cut key way.Not sure this is taper lock as it has a keyway and large key.
24mm bore and 132mm diameter v groove pulley. Held on with a grub screw in the Boss.
It has SPA 132 stamped in it but does not seem to coincide with Bearing Boys SPA series..lol
The taper lock are a combination of 2 part pulley giving lots of flexibility.Not sure this is taper lock as it has a keyway and large key
Lost me mate...need to check youtube i guess..lolThe taper lock are a combination of 2 part pulley giving lots of flexibility.
You choose a boss that matches your motor shaft, and a pulley of the correct size the tapper then pulls and locks the two together.( with matching grub screws.)
