inchpincher
2-stroke terror
- Tring, UK
My compressor is struggling with it's starting, it'll turn the pumps a couple of times then 'seize' and the motor whines. I usually catch this and turn it off (at the compressor) for fear of damaging the motor, although it did trip the motor the first time cause i didn't know what it was up.
I though the soft start might be broken so dropped the tank pressure down to 50 psi but same problem. I have been running the compressor quite a lot lately using the sandblasting pot. It's spec is a top range 3hp 3 pump 150litre tank, separate 15amp feed and lives in a warm garage.
The pressure switch kicks in about 95psi and fills the tank to 140psi ish. Is this a bit high and been overworking the motor
Thanks in advance,
ps. after turning it off/on/off/on/off/on it will usually get over what ever hill it's trying to climb and run fine But something obviously ain't right...
Thanks in advance,
