drummerboy
Hello,
I hope someone can help me, I definitely need it! I don't know too much about compressors, because I have never had to repair one. There seem to be some very knowledgeable people here, so I thought I would ask. I will really appreciate any advice anyone can give me.
I have an old Sears compressor which has a crack where the coupler for the air line connects to it. The sears part comes up as a regulator manifold. This part has been discontinued. I called devilbiss, and they say the same thing. I asked if there was another manifold I could use, they said no. It just doesn't seem right that there is no other part that will work. This part is in line between my tank and the pressure switch. It looks like the tank line and the pressure switch are both 3/8" pipe. OD is about .675" so I think that makes it 3/8", right? It has both gauges on it, one for the tank pressure and one for the air line pressure distributed by the regulator. It seems so simple.
So I just need another regulator manifold that accepts 3/8" pipe, or some way to step up or down to that size, right? Am I missing something? I am handy enough to fix this, I just don't know what parts I can use being inexperienced with compressor repairs.
Here is a picture of the part, you can see where I had to put jb weld to keep the air from leaking. Very frustrating.
http://www.sterlingfive.com/hffu76.htm
I hope someone here is able to help, I am really stuck on this one.
Thank you very much,
Joe
Joe
