I have an airmaster tiger 15/55 compressor which is approximately 12 years old, as far as i am aware it has only been used a couple of times when it was new and then it was stored until now. When the compressor is turned on the motor fires up ok but the pressure only builds to about 20psi, also the cylinder heads get very hot very quickly. there are no obvious air leaks although there does seem to be quite a lot of air coming out of the control box that the on/off switch. Any help or advice would be greatly appreciated.
