Hi ther, i have a clark 200L compressor, its got a 4hp pump and a 3hp motor (old motor failed and i had this laying around as a spare)
the pump is very noisy now, i thought it might be low on oil but it wasnt but i did change the oil as it was pretty dirty, so with fresh oil i thought it would be fine - alas no.
It runs for about 10 seconds then shuts off, if i turn it on again it will run for a little less time and shut off again, still really noisy, it will eventually build pressure but its not ideal and clerly not something i should continue to use as it is.
I really do not want to be spending £500+ on a new compressor, or even £200+ on a new pump if im just throwing money away,
Does anyone have any ideas what the issue could be, can the pump be serviced or is it just not worth it and i really do need to dig deep and spend on at least a new pump?
cheers
cheers
