vw1
- solihull uk
Hi all I have a second hand Clarke raider 50ltr 14cfm oil compressor previous one i had was oil free with a water trap. So for now i need information on water moisture oil filter set up ? , i plan on using the compressor to spray small areas on my beetle resto after welding in new metal panels .
I have looked at the info on here on using copper pipe and drain points drop legs etc do i need this for correct use for spraying small areas with epoxy primer on my car ?
Regard and thank you.
