JonnyAlpha
Hi;
I am considering buying a Media Blasting Cabinet and know that my 2.5HP 50L SnapOn will not be up to the task of running this or most other shot blasting rigs.
Has anyone tried the Wolf Professional
And this is the cabinet
. Cheap / small, though it seems to be doable, eventually you will get p!!sed off with it. Can't see what you are doing, takes too long, no space to move bigger things around, or 'that will fit but can't get to all the bits
'. Just yesterday a customer brought around a 'bike' frame, I thought it was a bicycle frame, turned out to be TRX Yamaha
. I at least didn't think it would fit inside the cabinet, it did but was difficult to get to all the areas. What I am trying to say, get bigger as you will need it, space is a premium. On the other side speed is related to nozzle size and compressor capacity. I had a 15cfm compressor running a suction gun with garnet as an abrasive. Little nick knacks OK but even a small water pump housing painfully slow, not to mention the compressor not being able to keep up. As the pressure drops so does the grit speed and the cleaning capacity drops. I have upgraded my small suction cabinet with bigger air supply lines air pilot operated main air valve and bigger air nozzle, the cabinet now works OK. Still very dusty inside even with two 3" air inlets and a 4" dust extraction. Air is fed from a 70cfm rotary screw with refrigerated dryer. So if you are thinking a 15cfm compressor get two, parallel them together and life will be more tolerable
