Rowan Sylvester-Bradley
- Newmarket, Suffolk, England
I bought an air fed mask from somewhere in China. When it arrived I found that it had connectors that were a slightly different design from the ones on my compressor and my air tools (which all use Euro connectors), so in order to make use of the mask, I need to change these connectors to Euro connectors. They are on orange plastic 8mm OD flexible tubing. So what I need is an adapter with a male Euro connector on one end, and a compression fitting suitable for 8mm OD plastic tube at the other end, and another adapter this time with a female Euro connector on one end, and a compression fitting suitable for 8mm OD plastic tube at the other end. I can't find any adapters like this. I can find male and female Euro connectors with 1/4" BSP threads at the other end, so what I think I need is a compression fitting suitable for 8mm OD plastic tubing, and a 1/4" BSP thread at the other end. I can find compression fittings like this but they all seem to be designed for use with metal tube, and have a copper olive. I don't think these will work with the plastic tubing. I think the olive will simply cut through the plastic tubing. Can anyone offer a solution for this problem?
Thank you - Rowan
Thank you - Rowan
