no problem at all. u can use soldered or compression fittings as wellIs ordinary plumbing 3/4" copper pipe ok for an air main ? I want to run a pipe the length of my shed which is only 6 meters long and take maybe three branches off it along its length , can it take the pressure of a normal compressor about 10 bar at the tank.
no problem at all. u can use soldered or compression fittings as well![]()
would that be trebble a 12gIf the pikeys want the copper they'll get a bit of free lead too , high velocity free lead![]()
would that be trebble a 12g![]()
3/4 would be better in copper than half inch as it would give better heat disipationI did my shop in 15mm copper a good few years ago and its never been a problem, not sure why you would use 3/4" though.
Money basically, the 3/4 is cheaper than the 1/2 for some daft reason, i thought it was marked wrong but apparently not.
