Cato
- Birmingham, UK
Truing a multi cylinder crankshaft once in a while is OK on the lathe, but I'm getting a few requests now so I need/want to set up something dedicated. Given the breadth and depth of the engineering knowledge on here I thought it worth asking for opinions and maybe sources for the bits.
It's nothing hugely complicated given what goes on here with some of you. Essentially it's a pair of tall narrow 'V' blocks sitting on a flat surface so that you can measure the run out at each end of the crank and adjust the webs accordingly. The usual tolerance to aim for is two thou, with a maximum of four.
A surface plate for the base would provide the flat surface and also allow positioning of two mag base DTIs. I can't see any suitable 'V' blocks available, so I'd need to get some accurately cut plate to make stands for the 'V'. Plain cut rather than with bearings for accuracy as I'm looking at run out rather than balance. Thoughts?
The next thing would be, is anyone on here able/prepared to cut some plate and make up the stands?
Ideally I'd buy a set up but they just don't come up and the balancing/truing machines are hideously expensive.
