I am making a belt grinding machine for the purpose of grinding out knives from flat stock. I have designed the machine in Solid Works and have started fabricating.
Hi ya,Where are you getting your contact wheel from Alik and what style of grinder are you building ? I've made a few knives using files and an Aldi cheap bench belt grinder but I haven't done any for a long time. I've made a couple of folding pen knives as well, they are a bit more of a challenge.
I am waiting to straighten one of my pieces of steel that got warped during laser cutting. When I have that back from work then I will be able to put in together pretty quicklyI've a forge and the correct alloy steel to make a knife, I'm interested to see what you do
View media item 8134View media item 8133Hi ya,
I didn't realise that all the images wouldn't load up straight away. If you look at the ones titled "image 1", "image 2", "image 3" they show what kind of grinder I am making. As to the contact wheel.......well I have gotten the drive and tracking wheels from Beaumont Metal works last time I was in the states. It uses mainly a flat platen to grind against so it doesn't have that kind of contact wheel. However, I will probably make an attachment for that in the future. Also, top wheel IS a small contact wheel holder and that can swap out wheels from 1/2" to 2" for grinding internal corners. Hope that makes sense.......
Ben
