lorenzo
Here's a nice little job we landed, custom fabing some parts for a Manatowic 888 lattice boom crane. This part is what we refer to as a spotter..... it will mount to the track frame of the crane, positioned between the 2 tracks. On the other end it will get welded to a massive auger system which is used to mix soil.
All the welding was done using...
MIG, Hobart Excel Arc 71, 1/16" dia.
OVC, 32
Wire speed, 300 IPM
Gas, 75/25
Pre-heated to approx 500* F
All the mill scale in the joint area was removed
Tack together "I" beam.... flanges, 1" x 15" x 60", web 5/8" x 19" x 60"
Next fab the pin ears, 5/8" plate......
Integrate the pin ears with the beam..... notice that the inside ears are slotted to pass over the web.....
Everything is tacked and ready for welding.....
After the "I" beam is welded I add the bracing as well as the tapered plates that will serve as the connection point to the auger assembly. After the welding is completed the pin ears are line bored.......
Notice that the bracing is reversed from one side to the other.....
Thanks for looking..........
OVC, 32
Wire speed, 300 IPM
Gas, 75/25
