i'm in the process of linking two 150L 3hp compressors,
i have set both to cut out at 120psi but the cut in pressures are miles apart.
one cuts in around 95-100 psi and the other at around 60-65psi,
is there any way of adjusting the cut in pressures or is it just how the switches are set from the factory?
ideally i was wanting a difference of around 10 psi cut in pressures between them both.
adjusting the cut out pressure on both switches doesn't seem to alter the cut in pressures either.
i have had a quick search on the net and seen a couple of pics of switches on other compressors with two adjustment screws but the switches on my compressors only seem to have one.
