T0rnado69
DIY nut !!
- Essex
hi all, i brought a cut50 from essex steam a while ago.
and only use it when i need to cut 6mm or above..
as for anything under 5mm i use a sureweld 34k
went to use it the cut50 the other day and it doesnt start up when you have the tip on the plate your wanting to cut.
as u lift or move the torch a bit it trys to arc up but doesnt.
like you was scratch starting a tig instead of using HF
changed the tip and electrode but still doesnt work right.
so i decided tonight to take the cover off and take a look inside and see if anything didnt look right
i think i may have found the problem, shown in the pictures below.
there seems to be 4 of these on the top board and one isnt connected on one side.
