Even basic Mitutoyo ones are only about £50, Mine must be about 8 years old or so, and had a fairly harsh life. Still hasnt gone out of calibration either.
I dont really do anyhthing that needs to be more accurate than 0.1mm, but its usefull to know which side of .1mm you are airing towards.
Normally used for stop setting on press brakes, measuring punches, drills etc.
Handy for doing decimal inch to metric conversions aswell
I would advice buy the best one you can afford, and look after it. It will last a long time.
I've had a couple from Aldi/Netto et al, for less than a tenner and they're surprisingly good.
If in doubt, put one up against a decent micrometer.
One thing, some of the cheap (and expensive?) ones loose the battery cover with extreme ease. Tape it on before it falls off![/QUOTE]
If your using it for machining, buy splash resistant, suds kills em, I have good bad and ugly ones for various degrees of accuracy, but use Mic's for anything to the 0.001"...... remember round bar and verniers shouldn't mix![]()
Thinking of getting a Digital Vernier, are they worth the money and what do I need to look out for?
Sid
YES
I've got 1 coolant proof Mitutoyo (£85) + 10 Neto (£8) ALL have exactly the same accuracy & resolution - 0.01mm. As long as the neto ones dont get soaked they stay ok.
This way I have one on each machine instead of running up & down the w/shop cos what you want is always at the other end (why is that).
I will be using it mainly for machining, can you explain "remember round bar and verniers shouldn't mix"
Or a calculatorwork in metric and imperial and your need 2 of everything.............
verniers on round bar are pretty inaccurate, OK if your doing say, bar to fit hole type jobs,
Or a calculator![]()
verniers on round bar are pretty inaccurate, OK if your doing say, bar to fit hole type jobs, but there only very rough at measuring much more, Micrometers are the tools for measuring work on a lathe, as they can be calibrated easily with an anvil, and will measure accurately to several decimal places, some of mine down to 0.0001", not that I ever need the last decimal place, the problem with verniers is theres no feel on the tumbler, unlike a Mic which has tumblers on torque settings, also the surface doesn't really read over a big enough area.... The problem with Mic's is your need several sets, say 0-1" 1-2" 2-3" 3-4" etc etc depending on how big your going to work, I have up to a 1' and id dread to think what a set like that would cost..... work in metric and imperial and your need 2 of everything.............
