Got my hands on a free 1000 Liter water container, Roughly 4x3x3
My plan is, to flip it upside down so the Filling cap is on the bottom, then secure a collection hood over the opening, then putting some mesh over the top of the opening in the inside to stop large items falling down. Then using a simple hand held brush to push the media down the collection funnel.
The media will then be collected into a 25l Container, which will then be recycled back into blasting media.
I also plan to cut open 2 large openings onto the sides. One for a Clear Screen, and the other as an opening for a door.
I will also be cutting 2 round holes for some extra long gauntlets for protection.
I plan to fit 2 x Outside security/ Flood lamps to the inside to Illuminate the contents.
For the Air supply, I will be Double Filtering the Air entering the Cabinet, a Trap at the compressor (Which is used for Everything, From Air-tools to Spraying) and then adding an Isolated one on the Cabinet itself.
For Blasting, I will be using an eBay Mid-Range suction fed good. Ive seen one of these at work, and although not the best, will work for what i want it too (Which will be mainly Wheels and Suspension components).
Now, what I'm really stuck on, is Extraction. I'm not 100% Sure if its needed? However, I'm after a CHEAP solution to extraction if its needed - Would a hoover be sufficient enough?
The next bit I'm not 100% sure on, is Media. I Plan on mainly blasting Wheels and Suspension components. With a mix of Steel, alloy and Cast Iron (Depending on Vehicle)
Any thoughts and ideas would be greatly appreciated.
