steve.h
Fire Starter,,,,
- swindon sn4
So I have seen several threads on here about gas and solid fuel forges, so I was thinking. Can I build a small forge something like a steel cube with open top, with a gas burner entering the bottom as well as blown air but fill the chamber with small bits of lava rock. I would imagine it to look simmilar to a blacksmiths forge, but obviously gas powered with the rocks to hold the heat, as well as insulating bricks or fibremat around the walls.
would this work very well, i thought it should be more efficient than an empty chamber as that has very little to trap the heat...
so what do you all think ? ? ?
(wouldn't move when it was cold)
