Hi, I'm looking into DIY-ing a pressure pot for sand blasting.
I have a compressor capable of 160 CFM.
I have an empty lpg gas cylinder.
Cfm charts suggest piping should be 1.5" to take advantage of the 160CFM.
But does this mean all the pipework and fittings on the blast pot itself should be sized to 1.5" ?
I may not need this hose size for the actual sand blast gun most of the time as it would probably be unwieldy, however I want the pressure pot itself to be capable of the full compressor output when required (and just swap the sand blast gun hose when needed)
If so does this mean the output port on the pot (where the abrasive is forced out into the metering valve) needs to be replaced for a 1.5" ?
Any advice appreciated
Thanks
Thanks
