Hi all
This is the first time I've sprayed. I have a reg fitted at the gun which should be set at 35psi when fully triggered. My question is do you fill the gun with paint then set the psi? I set it BEFORE I filled it up with primer. When I pulled the trigger back with primer in the gun the psi, when triggered, dropped to around 20psi (i was spraying thick epoxy primer). Did the psi drop from the 35psi setting (before I filled up the gun with primer) to 20psi because of the thickness of the primer being sprayed? thanks
johnny
johnny
