Mates house.
RCD keeps tripping on the cooker circuit. Doesn't go straight away takes about 10 minutes.
Cooker circuit breaker itself doesn't trip.
There is a cooker mains switch with a socket attached. This is fine. Even when the cooker switch is OFF the RCD trips.
The cooker looks very rough. Could it be tripping the RCD even with the mains switch off? I wouldn't have thought so.
I once had something similar and it turned out it was the 32amp breaker itself causing the rcd to trip!
Any ideas?
Any ideas?
theres a double pole isolator switch or a cooker controll switch with socket check the switch to make sure its not knacked and letting power through
