Ok after my son was assisted by "Des Marples" from West Yorkshire Engine Services" we had to replace the turbo on my Navara D40.
To say I was surprised my son was taken in is an understatement. It just shows the power of You Tube.
Anyway suffice to say we got the turbo fitted and the exhaust system was filled with oil.
My son has taken everything that got filled with oil to work and hot steam cleaned it.
Refitted it and then we got the dreaded DPF light come on.
So as he did not take the DPF off we have now done that. But and this is what we are not sure of. Can we use a degrease and clean the oil out. (We are hoping that cleaning the sensors, might help) but as currently we are not trying to remove soot and Ash from the DPF , just oil, is a degreaser a good option.
We are aware the DPF might be blocked by Ash and soot but as we got no DPF light code 2002 showing previously just loads and loads of grey smoke. (Worse than James bond) we are thinking if we can run it hot enough to force a regeneration , it might clean it a bit.
Failing that is there any software that will force a regeneration...
