oilcooled :)
Pipe Welder, Mechanical engineer
- Ireland
i have a kinda idea of what duty cycle is but not fully sure
say an electroweld 250 air cooled has 10% @ max amp, so does that mean if im putting a rod down at max amps if i run the machine for 1 minute staight it needs the other 9 minutes for cooling. i was thought 100% was over a 10 minute period. if you exceed the duty cycle then does the thermal protection kick in on a air cooled? cause the air cooled i had use to always heat
on my oil cooled it says max duty cycle k.v.a. 5 what is that in percent?
just curious or am i way off the mark
say an electroweld 250 air cooled has 10% @ max amp, so does that mean if im putting a rod down at max amps if i run the machine for 1 minute staight it needs the other 9 minutes for cooling. i was thought 100% was over a 10 minute period. if you exceed the duty cycle then does the thermal protection kick in on a air cooled? cause the air cooled i had use to always heaton my oil cooled it says max duty cycle k.v.a. 5 what is that in percent?
