i routed a carbon steel pipe using stick electrodes with the earth on negative and the electrode holder on positive, will it fail under x-ray test?
why did you do the weld if you thought you may lose your job over it?
is it going to be x ray tested
just out of curiosity what is it for
i cant the remember the specifications of the rod.
i do know they were fillarc 88s 2.5mm flux cor, if that helps.
you can use this stick - or + pole current
and you may well go to sleep today
