P p0689109 Member Messages 1,961 Location stoke on trent,england Oct 31, 2012 #1 What are the advantages/disadvantages to using a 2pole 2800rpm motor to a 4 pole 1400 rpm motor? I realise that to get the same pump speed I will have to have different size pullies. Regards, Michael
rtbcomp Moderator Messages 18,574 Location Sheffield UK Oct 31, 2012 #2 For a given power you get more torque with the lower speed. Power = Torque x Speed Also with the lower speed you use a larger motor pulley which reduces the chance of the belt slipping.
F ford34/2 Member Messages 2,280 Location Cramlington,Northumberland. United Kingdom Oct 31, 2012 #3 The rated full load torque is almost twice the rating on a 4 pole 1425 RPM motor against a 2 pole 2850Rpm on a 3Hp BrookCrompton- a 2850 would have a full load torque of 7.3 Mn/NM a 1425 would have a full load torque of 14.5 MN/Mn or check the brookcrompton website. Stan
P p0689109 Member Messages 1,961 Location stoke on trent,england Nov 1, 2012 #5 Thanks for that. I thought the torque would be better, the quieter running is a bonus though. Cheers all Last edited: Nov 2, 2012
shenion Tool Pack Rat Messages 7,586 Location Stone Mountain, GA USA Nov 1, 2012 #6 The larger pulley needed for the same pump RPM will negate the torque if the lower speed motor. It might have easier starting though.
