Hi all, back again still researching the best way to do my engine bay for a clean smooth look for show car type detailing.
I would like to ask all the basics on Seam welding.
Firstly, What are the advantages of seam welding?
I imagine the seam welding would be much along the same lines as say putting a larger sway bar in, it would create a stiffer front end etc,am I right in assuming this?
Is it better to weld the full seam or do staggered inch long welds along the seam?
When the seam is welded in either fashion (above) will it strengthen the jiont strong enough to use body filler (bondo) to smooth it out and reduce the risk of cracking?
Once welded will there still be flex to cause cracking in Body filler(bondo)?
Most area in my bay will have body filler(bondo) only a couple millimteres think but in 2 small areas approx 5cm square will be roughly an inch think as long as it is done in stages it would be fine to fill?
I have an ARC welder basic set up will that do ok for the seams?
Apoligies for any questions that are general basic stuff but I want to know as much as possible before starting the project.
Thanks for any help
Cheers
Thanks for any help
Cheers
