Woody.v8
Blue gluer
- staffs
As above Ive altered some hubs (cast steel?) and turned a mild steel disc and welded them to the hub, Now I need to turn one side of the weld flush as there was a good sized prep and still be loads of weld in the prep,
The problem is it seems mental hard when on the lathe are these rods meant to be machinable? If not can anyone recommend a better solution as i will be needing to do a few but they need to be strong as they are for my stockcar and will need to be good for 600-700 bhp and similar torque as well as its full contact
I used dissimilar rods with not knowing the composition of the hub but just assumed
that they would turn OK.
I will add some pics if it helps..Cheers...Pete
.I used dissimilar rods with not knowing the composition of the hub but just assumed
that they would turn OK.I will add some pics if it helps..Cheers...Pete
