Onoff
- Sevenoaks, UK
Looking at a bit of future proofing, that I'll need to learn sometimes and some landscaping here and how I thus might install an EV point some distance from the house. Starting from a zero knowledge point but picking it up I think.
I've got to decide on the likely run from the house cu and do my volt drop calcs before looking at buying ducting, cable etc. Digger man lined up as and when! Then to include enough slack in the cable and allow for that in the calcs as later I'll be moving the cu from it's present position in the porch about 3m inside the house and at an accessible height.
As a first point of call I dived into the TLC website, always good for technical downloads!
Reading the first EV charger bumpf that came up. Call me picky but "We recommend the use of a Type B curve circuit breakers"? It's not plural, it should be "breaker" or drop the "a". One must have standards!
Then this. Read literally it would suggest they want you to break into the incoming split con cable to find the live! Anyway, shouldn't it be "line" now? It's the seperate tails after the head fuse and before the meter I guess? The current clamp prevents you popping the 63/80/100A incomer I believe.
Not the worst Chinglish I've come across but it worries me a little what else they've "missed".
My immediate question please is what is the purpose of the Cat-5 cable that's run with the SWA and how does it connect both ends?
Cheers
Cheers
