winnie2457
Hello I have a 47kg gas bottle going to use it as an extra tank for my 25L 2.5hp cobra compressor running 9.5cfm and 115psi
Question is do I put a t piece on the output of my compressor I know the second tank will only be at regulator pressure but I always have this on max as I have a second regulator on my airline. And basically run a single pipe from the tee into my second bottle and will this suffice
Or do I need to run a line from my compressor to a t piece on my second tank then a second line from the tee on my second tank to the tool if you know what I mean
Basically do I need a single line to the tank to act like a reservoir or do I need a flowing circuit to the second tank it's hard to explain if you get what I mean
Any help much appreciated thanks
