Hi, I recently got my hands on a faulty compressor. It will start up for a couple of seconds then the safety switch will cut in and turn it off. So I whizzed the motor off, stripped it down and cleaned it. I greased the bearing as it was a little stiff(was used in a factory with flour, it was everywhere). Then when it still didnt work I removed the safety switch and tested again. It fired up and will run and compress air as it should, but after around 30 seconds the remaining flour/string on the motor coils starts melting and it starts smoking.
What could be the cause, could it just be the coils are knackered, meaning it will need a new motor? Does the motor need any form of lubrication?
Last of all, if I can get a motor are they generally unversally fitting? Its a SIP 2hp 50ltr. It will only be used for general household dutys
Cheers
Cheers
Does it make any difference that its direct drive? I probably should have mentioned that earlier.
