Hi Folks,
1st post here but have always used the forum as a really usfull resource and project inspiration.
I've recent 'aquired' an old unimig 240 pro series machine. Came out of an old bodyshop so it took a bit of scrapping of overspray to actually find out what it was - the bonus on my part was it came with a full size boc argoshield light bottle foc
Initially nothing worked - don't think it's been used for 10 years, and was full - I mean full of dust & red overspray - red oxide colour lol....
I've read quite a few posts here and now have the thing powering up, the wire feed working, gas valve opening etc.
Put a new euro torch, got the bottle filled, and a new coil of wire on at this stage.
And pop - just a fizzle, like a light bulb fillament with 0.8mm wire. Same on all settings until I turn it up to full power then it blows the trip.
Tried my dc clamp meter over the ambilical cord but it just blinks?
I suspect it may be the contactor as it took alot of messing to get it to work initially, so will source a new one of those in the next few days,clean upthe connections - they're all tight, I'll put an new earth lead and clamp on it too.
I've gleaned from info on here that it may be the diode pack - how does one test it - my meter has a diode test setting but i've never used it?
Other question is what polarity should the torch and earth be for welding mild steel primarily? There's also 2 negative conections - I beleive for spray or deposition with what looks like a diesel glow plug symbol above - which should I use?
Last question for now is what's the second main rheostat / pot for on the front of the control panel, I think it's probably a spot timer (the print is gone here)? There's two smaller 'screwdriver' style pots for burnback and ramp settings.
I'll get a few photos later.
Thanks Steve
PS I also got an older spotmatic M2 in the deal for an extra £20 so know doubt I'll have some questions about that too.
Thanks Steve
